Gainsborough Ambassador shower dripping
17 Nov 2005
Manchester
I have a Gainsborough Ambassador shower that runs from mains water, it drips from the thing you turn to start the shower and also drips from the head. I will be doing some other bathroom jobs and the tiles will be coming off. I don’t mind keeping the shower as it has been fine apart from this and I can jazz it up a little with a new pipe and head.
What can the issue be please? I’m sure I read somewhere (may have even been on here) that the cartridges can be replaced, a quick search and these seem expensive, would it be better to replace it with a similar shower that uses the same pipe work orientation (not skilled enough to change pipes)
Thanks in advance.
It’s likely to be the cartridge, and it is expensive, but ask yourself the following:
Is it more expensive for the cartridge to be replaced than altering pipes?
If you replace the cartridge, is anything else likely to go wrong?
Thanks CBW, what else could go wrong with the shower please?
How much can you find the carts for please?
I had a dripping shower valve once and turned out to be a bit of grit somewhere in the valve. My plumber sorted it.
Is it a bar shower, or round?
The round one looks like the high-quality Aqualisa, and even takes an Aqualisa cartridge, but is cheaper. a new replacement mixer does not cost much more.
IMO it is worth descaling while you have it apart. Sometimes this, and replacing the O rings, will cure drips, but changing the cartridge is less work.
Not much more could go wrong, other than a failed o-ring, but pretty sure they come with the cartridge. Cheapest I’ve found is approx £150.
Hi, it’s a round one.
seems to be pretty good
bearing in mind the lower price, consider just getting a new one. Not vastly dearer than a cartridge.
If you like tinkering, you can take the old one apart on the kitchen table; descale it, clean it, polish the moving parts, reassemble with new O rings and silicone grease; swap it back in ten years if necessary
edit
Burnerman beat me to it, but I mean the shell and knobs as well
