Hello,
I have a shower Gainsborough Energy 3000X 10.5KW which has been working fine for several years, however, recently the water temperature has been either very cold or very hot. Previously it was possible to set the dial at low and the water would be a little hot and medium a bit more hot. Now both these options do not work and the water is cold. If you select high the water is hot and suitable for use. After 20 minutes it gets too hot and you have to step away for 30 seconds until the water reduces heat and safe to use again. This use to occur once in a while but now is a little frequent. Is this something to do with the thermostat? Do i need to install a thermal cut off part. Where can I purchase this shower from ? and do they still manufacture them, just in case I need to replace
