Gainsborough shower always boiling hot or freezing cold.
25 Aug 2010
South Glamorgan
I hope this is in the correct area.. new to the forum.
I have a 9.5KW Gainsborough electric shower, approx 2 to 3 years old.
It turns on fine, however I need to put this on to maximum temperature to get the water to heat up. When I turn the temp control to cool it down slightly this does not change the temperature until I get close to the blue section and it will go straight to freezing.
The shower does sound like a kettle when warming up...almost as if it is lacking in water. Is this possible, if so can it be repaired?
Yours hopefully.. Simon
9.5 kw what model is it SDL, SCL, E ?
sounds like you have a flow issue with the temp control dial.
many Gainsborough showers now have what is called an engine and is only the complete unit that can be changed and at around £65
is not really worth it being they are a bottom of the range electric shower.
Sorry to hear about this fault.It sounds as though the 'thermal trip' is starting to activate.It's an internal sensor fault which can only be cured by replacing the 'engine' which is every single working part of the shower.
If you replaced the engine it would be a like for like fit with no modification needed to either the plumbing,electrics or tiling.
All spares come with a one year warranty.
Hope that this info helps.
