Galaxy 2-12 Problems
3 Oct 2021
Can anyone help me? I am not a security alarm engineer. I am, however, a Fire alarm engineer, so not a stranger to systems. I installed a Galaxy 12 zone panel in my bungalow 7 years ago. As I work for Chubb, I purchased from them a triangular, Chubb bell box. It has been ok for the 7 years since install. Now, it is sounding intermittently for a few seconds, but nothing displays as a problem on the key pad LCD screen. I checked the log and it displays multiple system tests. My wife works nights and heard it sounding at 03:00. The log has a report of a system test at the same time (aprox). As it has never done this before, I am unsure what to do other than disable the "system test", if possible.
Pete
Can you post an image of the log. The Galaxy performs a couple of different test types. Since you self installed, I'm assuming comm's isn't set up. If that's the case, then it only leaves the power supply tests that load test the battery at regular intervals. A failure of that test should start flashing the keypad LED though. Do you know which firmware level you have ?
