Hi
I have an ADT branded Galaxy 2-12 wireless system.
I was wondering if anyone has successfully installed a new PIR sensor to such a system?
I had a problem with a PIR triggering for a while, then it stopped. Turned out it stopped because it is now dead. Replaced battery. No better.
It is still linked to unit, as the tamper is still registered by the main unit. But there is no red led or any detection. I have walked in when the alarm was turned on and it didn't register me until I entered a different room, therefore it is not working.
There is also a switch in the PIR labelled A-B, I have no idea what that is for, but tried it in both positions to no effect.
I do have the engineer code, and have done walk tests, zone programming, and so forth, so should be able to do it if I know how. I would rather not pay £100 for someone to come out and fit a £30 sensor.
Presumably, I need to buy a new compatible sensor, get sensor in some sort of 'link up' mode, get RF panel in some sort of 'link up' mode, and scan in the sensor somehow, then associate that to a zone, then program the zone etc in the usual way.
Wireless PIRs must pack up occasionally, so hoping someone has done this before...
Andy
Andy
