Galaxy Aqua 4000 8.5kW shower problem
28 Mar 2013
Cheshire
Hi Guys,
If i turn the shower on using the LOW or COLD button the shower works, If i turn the shower on using the HIGH button it starts and immediately switches itself off. If i turn the shower on using the LOW button and leave the shower running for a few minutes and then press the HIGH button it is fine.
I have just changed the pressure switch assembly but this has made no difference.
Can anybody help me???
Thanks in advance. Karl.
As long as the water pressure going into is ok then it sounds like the temperature control thermostat is faulty. if replaceable try canging that 1st otherwise its the pcb I reckon. javascript:emoticon(':(')
Hi Peter,
Thanks for the reply, I will have a look to see if the temp control thermostate is replaceable.
Regards
Karl
Check the button on the pcb by removing the cover and operate the button by hand it's poss it may not be latching properly.
Hello
I am experiencing the same problem and saw your post on this blog. Did the suggested advise work or how did you resolve the problem
