I had this installed professionally not so long back and all is well, however, I didn't look into the full array of features and now want to get those done.
The G2 has an area on it's board for Phone line connectivity etc... reading the manual states that it can send text messages and alerts if hooked up.
Now, when we moved in last August I wired the house with CAT6. I currently have my BT line extended over CAT6, presented in the loft and distributed.
The 'installation' manual I've read for the Galaxy suggests that the line fed to the panel must be the master line. Technically, although extended by CAT6, I can present the master line to the G2...
Would this be ok?
Would simply adding the line to the G2 panel allow it to be able to send alerts via text to me?
Given that I distribute the phone over CAT6 would I need to bother looping back out of the G2?
Also, on matters unrelated to the PSTN connection, I'm toying with the idea of changing my bell boxes from fairly standard LED blinking sounders, to the Pyronix Deltabell's which look nice with their backlight.
I'm not comfortable with opening the panel (worried I'll never get the tamper back on and end up with a non-functioning alarm), but I work in IT and am fairly savvy when it comes to IT stuff, just not so much with other kit. The fact the G2 has resistors scares me, as I don't really understand that stuff.
However, I was wondering if it would simply be a case of disconnecting the existing bell boxes and swapping the 6 core straight over to a Pyronix... If it's not as simple as that, I'll leave it, but if its simply taking the cables out of the old and hooking up to the new, then I could manage that.
I've got full engineers access to the alarm etc.
Any help would be appreciated.
Would this be ok?
