Hi all got a gd48 galaxy that has 2 delta bells wired to it there is a fault on the bells as it's grade 3 with fault resisters on bells 1k 1k,
fault output from bell is wired back to outputs on panel which is programmed as bell batt fault,
However keeps saying bell battery fault when you exit engineer mode
Just wondered what does output have to be programmed as to monitor bell fault for a grade 3 system? Thank you
