Gap at bottom of UPVc door
12 Dec 2011
Yorkshire
Hi All, i was wondering if someone had any ideas whats happening with my door. when i shut it and all latches are down i can still see daylight through the bottom 6inch of the door where is does close enough. can feel a bit of a draft half way up door and its fine at the top.. any ideas if i can fix this?
I expect it wants adjusting, two possible reasons, i the cams are not pulling the door into the seal, or the door is adjusted wrong in the frame, in which case the cams won't engage where they are supposed to. Some pictures of the door and the mechanism would help
