Hi
Confident and competent DIY’er here, after some advice on gaps between boards please ??
I’m going to plasterboard the stud walls and overboard the ceilings to make life easier for a plasterer to skim them. I get frustrated that in 2025 there are still crack lines in plasterboard even when they’ve been taped. You’d think there would be a modern solution to this issue by now
Do I butt the boards up together with no gap at all, or do you leave a 1mm or 2mm gap for expansion between sheets ?? And what distance should the screws be apart please ?? And I take it you use square edge, rather than tapered boards ??
Many thanks,
Graeme.
Many thanks,
Graeme.
