I was intending tiling all the bathroom walls yes. I may have to build stud wall where shower mixer will be (wall only 1200mm wide + the door) Wasn't thinking of bringing it out 90mm though but you may be right. This is the shower
http://www.diy.com/diy/jsp/bq/nav.j...search&ts=1267368387250&isSearch=true[/QUOTE]
That’s not a recessed mixer, you should be OK but will still need to chase for the pipes.
Two of my bathroom partition walls are combination of brick built on its side and 2x3 timber (all old way of doing it). If i d&d will it crack at these points (wood/brick) or nothing to worry about.
If I’ve understood correctly, position a board 50/50 over the brick/stud then board out either side.
Same when you get the odd embedded piece of wood that the original wooden window reveals or skirting were nailed to...Is it best to scrim these 1st?
Don’t really understand what you mean.
Will give dot dab ago with wooden spoon and try get it a bit more consistent. I threw it on just with a normal round nosed trowel. I presume it is correct to throw onto back of PB and not onto the wall? I say this as it started getting v.heavy and bending with weight of adhesive (but like i say think i over did it with amount of dabs -ain't coming off in a hurry for sure!).
Put dabs on the wall, as stated.
