I have covered the two walls around the bath with plasterboard and am about to tank before fitting the bath back.
Unfortunately being my first time I have the following problem:
I attached the plasterboard to one wall and it fitted into the corner nicely.
I then attached the plasterboard onto the second wall. However, in the corner where it meets the first plasterboard, there is a slight gap that gets bigger the higher up you go (to about 1 cm gap).
Tiling should cover up this gap however, do I need to fill it with anything so that when I apply the tanking product there is a surface to cover and the whole area will be waterproof?
