Hey
I’ve read some threads on here and seen various recommendations. I’m not sure which to go with. Most of the threads are for quite large gaps. My gaps max out at 5-7mm. Would I go with caulk or would you recommend using some toupret or easifill? I couldn’t work out from the other threads what the rationale was behind each solution. Obviously my main priority is avoiding cracks and having to repaint
It’s standard plastered walls and softwood skirting. It’ll be painted in white water based satinwood (crown quick dry).
Thanks all.
Thanks all.
