Hi all,
Trying to put a stud then internal door frame up against a stitch drilled 100mm thick clinker block wall. Really didn't want to disc cut - but due to the slight stagger in some block laying, a couple of iffy blocks and then my slightly iffy stitch drilling I've a bit of a rough surface ranging from 5mm to 20mm gap in places - and one part of the wide gap is about 3 courses high.
Foam, gripfill, Mortar, vintage newspaper that I pulled out from my previous house?
Theres a bit too much volume for grip fill I'd say and the main gap makes me wonder if foam really is best so I'm thinking mortar for various reasons - but are there pitfalls to that?. It's the opposite side to door hinges - won't get banged much, doors are quite heavy but smooth action so its actually hard to slam them.
Cheers for any thoughts.
