Why is it that Angle grinders don't have a facility to follow a straight edge, and manufacturers don't make diamond blades for circular saws. Is there some reason that we shouldn't attempt to get diamond blades to cut in a straight line?
I've been making my own router table and had some nice sheet stainless steel that I wanted cut down to use as a top. As soon as I attempted to cut it, I found that this stuff is diabolically tough, and takes the teeth off every sort of blade you can imagine. Eventually in desperation I took a diamond blade off the angle grinder and (with a bit of a bodge with a washer to make it fit on the arbour) put it into my circular saw.
Clamped the steel to the worktop with a straight edge and run the circular saw up it. Did the job a treat. This stuff is so tough that I couldn't even use a file to take off the burs, (it just skipped over them without any hint of cutting).
Why don't they make these blades for circular saws? Failing that, why don't angle grinders have an attachment to follow a straight edge?
