Hi all - I'm planning on sanding & oiling my living room floorboards after lifting the carpet, but there are small gaps in between the boards - maybe 3-5mm throughout. Below the floor there's a decent void (3-4 feet) before soil, so smells rise up but I also have access to the underneath. I'd like to seal the gaps, but I need to ensure that this is relatively air tight, somewhat flexible and not obvious from above.
My current options:
Cut fibre board to size and nail from underneath
Problem: joists are irregular so this will leave gaps at the edges and there's not enough space under the floor boards to use a saw or handle full size sheets so it would be a pain
Tape from underneath
Problem: pet hairs and general dust will stick from above
Insulate with glass fibre from underneath
Problem: not airtight
Caulk from above
Problem: difficult to get it to stick in the wider gaps and wouldn't be the best look against the wood when viewed from above
As it stands, my best idea is to tape from underneath with a few staples to hold the tape tight and then caulk from above, trying to keep the caulk well below the top of the wood and using something cut from plastic as a spudger to smooth it out, staying below the top level to reduce how visible it is.
Anyone have any better ideas?!
My current options:
Caulk from above
