gaps in floor
27 Jun 2004
I am in the process of laying oak planks as a floating floor onto a concrete
surface.
It appears due to variation that some of the planks are under/over width and as a result I have gaps. Also the planks are tongue and grooved long sides only so there is slight variation where the ends meet.
I was going to mix the sawdust with pva glue to fill the gaps.
Will this be okay. WYL on a similar post, what do you mean by plastering the whole floor?
I should point out that the gaps I am on about are only 2mm ish. but are obviously visible.
Regards
Kev
________________________
moderator
please note 20 your post has been split
Plastering the whole floor with woodfiller and sanddust is only applicable when installing/sanding a parquet/herringbone type of floor.
Filling the gaps in your floor will result in having to do it time after time, because of the natural movement of the boards during the seasons.
did you install a DPM before installing the floor?
Other remark and don't get me wrong about this: but differences in width in boards from the same batch normally indicates wrong storage at supplier (i.e. 'cheap' prices?)
thanks for that.
I thought the price was about average but the quality is cheap... i paid £35 a metre.
I thought of sending the bloke a square so in future he can cut the ends straight :confused:
The concrete floor has lino tiles on top (like you used to get in kitchens
well stuck down all over). I have put a 1000grade DPM plastic over the top and the floor is floating with the tongues pva glued.
trophykev said:
thanks for that.
That's steep! (For the quality received I mean)
That's good. And sound insulation? 2 - 3mm foam? I'm sure you have thought of that.
