Hi guys, I fit some skirting yesterday and it was more of a pain in the backside than i expected. Basically where my wall met the floor, the angle was not 90 degrees hence none of the skirting actually sat 100% correctly although it looked fine to the naked eye. The problem I had was for example when mitering for 90 degree angles, the two mitered pieces would be off by a few mm, with the worst one being off by like 3mm.
Similarly on a very long wall i have it where although two pieces join together, they are not actually very snug, still around 1-0.5mm apart.
Is this something everyone would experience in a situation as mine and would they use wood filler to solve the problem?
In my case i have mdf skirting and furthermore, is wood filler (particularly ronseal) durable enough. I dont want it to crumble off later on
