- Joined
- 10 Nov 2007
- Messages
- 162
- Reaction score
- 4
- Country
I'm about to revamp a garage (tiles, shelves, new lights, new sockets) and would like to run a "bus bar" (or whatever they are called) around it. Like you see in commercial/industrial buildings, a giant surface mounted conduit box with the sockets and light switches fitted into it.
I'd also like to run a feed for a (dual) electric oven into the kitchen next door.
The layout is as below:
http://www.cosic.org.uk/MarkoStuff/misc/1.gif
http://www.cosic.org.uk/MarkoStuff/misc/2.gif
http://www.cosic.org.uk/MarkoStuff/misc/3.gif
http://www.cosic.org.uk/MarkoStuff/misc/4.gif
Consumer unit is green in the first picture, the second picture shows the existing light switches (1x room, 1x bench both off one 10A MCB) and sockets (2x ring main, 1x welder 13A fused outlet like a cooker, one MCB for ring, one for welder) on the back wall and the door through to the house.
I would like to run that conduit with sockets in at a height of 1.2m off the floor, all around the back wall and consumer unit wall. (it could then kick upwards to go to the consumer unit, if necessary)
The cooker is on the other side of that back wall. It would need a new wire from the consumer unit. I'm fairly sure that there is room, will check and snap a picture of the unit in the morning. It's a 1990 house/consumer unit, and everything is on a 30mA or 100mA RCD.
Can the cooker cable run inside the conduit bus bar affair before going through the wall? It'd make life very easy if so!
In going through the wall and running a short while along the surface on the other side, what sort of conduit is required?
Any ideas where to buy the conduit bus bar affair as a retail customer?
Common sense, electrical design and physical implementation I'm fine with, sourcing bits and regs I'm unsure of as this isn't something I'd do every day!
I'd be after an electrician in Pembrokeshire to fill in the relevant paperwork/hook into the consumer unit too - any reccommendations for folks that have actual common sense/practical skills and not just a certificate? I'm after quick sanity check, rubber-stamp, flick the switch type stuff rather than them doing the work.
Cheers!
Cheers!
