In the garage, I want to sort out the ceiling which is proving a bit difficult.
The joists are not all the same height (measured from the floor) and I have boarded the ceiling using plasterboard. However, due to the joists not being quite the same, the ceiling has a few bulges in those locations and also, the joists were sometimes a little to far apart which made the joints between the board a bit (too) flexible.
I wanted to get the ceiling plastered, but the plasterer did not want to do it because of the flexing of the ceiling as well as the bulges.
What would be the best option? Is there such a material that can be put on the ceiling that is thick and flexible which would not crack on the joists?
Failing that - would the only option be to batten underneath the boards again and put another layer of plasterboard up?
Appreciate your responses
