Help please,
I'am doing a garage conversion and need to install 3 new rads in total. I have a feed coming into the conversion (15mm, inlet and outlet) done by a builder at an earlier date, currently just capped off.
I have plumbed in the 3 rads and the pipes now all need to be connected up to the system.
What is the best way to do this?
My thinking is that I continue the feed and create a loop linking the 2 pipes coming into the garage to each other and then take individual spurs from this loop to each new rad. Is this correct?
To add further to this I don't know which of the pipes into the garage is the inlet and outlet. Does this matter as long as I fit all the rads the same way?
Also I want to connect the new 'system' to the feed coming into the garage with stop valves so I can turn it all off if there are leaks in any of my new joints. Is this ok?
Any advice will be very helpful thanks!
