Hi there, I'm looking for some advice on doing a DIY garage conversion but have a few questions... I have a diagram of what I am hoping to achieve in case it is not clear from my explanation!
We have a part integral garage which can be accessed by a door from the kitchen, we would like to make this into a utility room type area. The garage ceiling has a bedroom above it and is already plasterboarded and artexed so I assume that nothing more will need to be done here.
The existing exterior facing wall is a cavity wall so I'm thinking that this can just be plastered as can the 2 existing interior facing walls. I need to build a timber stud wall to divide the new room from the rest of the garage, I was planning on using fireproof "pink" plasterboard on both sides with insulation in the middle.
The concrete floor needs raising so I was thinking timber joists placed width-ways across the garage floor, insulated inbetween the joists and then chipboard over the top?
Does this all sound sensible so far? If so then I have a quite a few areas I'm still not sure on:
- Would I build the stud wall first, fixing it to the concrete floor or would I build the timber raised floor first and fix the stud wall on top of this?
- What sort of damp proof membrane do I need over the existing concrete floor and where exactly would this go?
- How can I best ventilate this space as it will have no windows, do I need some kind of trickle vents built into the stud wall or perhaps an extractor fan or both vents and a fan???
Here is the diagram. Thanks in advance for any help!
[/img]
[/img]
