I am strongly considering converting my garage into an office and utility/WC but to be honest, whilst I know what I want, I'm not sure where to start.
I have planned out the project on Sketchup here - //www.diynot.com/network/Joshwa2k/albums/24589/92734 and spoken to an architect (indirect family friend) who quoted £1k +VAT to do a site survey, proper drawings and building reg requirements. This immediately caused me concern that the whole project would cost a lot more than expected (I haven't proceeded with this yet). I then had a builder (again Friend of the family) quote for the work itself and they have quoted £5.8k for the building work, £1.6k for plumbing & £1k for electrics (again all +VAT). This doesn't include for things like WC & Basic unit that we will supply).
The total for the whole project is much more than I expected and I am torn because I feel I am not incapable of doing much of the work myself (stud walls, plasterboard, suspended floor etc.) and get Builder/ Electrician/Plumber/Plasterer in as and when required.
However I wouldn't know where to start with regards to the building regs etc. and I feel £1k +VAT is quite a lot given the relatively small project.
The rough scope of work is:
- Support load bearing wall and form opening from Kitchen to new office area, insert lintel and door liner and hang existing 1200mm doors that I will supply. Work will need to be completed by a builder.
- Support garage rear wall and form opening for window, install 915x1200mm uPVC window. Builder to supply window and complete work.
- Brick up existing garage door
- Insulate between existing roof joists and fix two layers of 12mm plasterboard, tape and skim. I could easily do this and then have it skimmed by a plasterer.
- Construct stud-work partition walls to form divide between what will be left of the garage & office and office & utility room. Again I could do this and have it skimmed.
- Prepare existing concrete floor with 2 coats of liquid DPM & lay 50x50mm timers to bring garage floor up to existing kitchen floor level, infill with 50mm Celotex & cover with 18mm plywood. Again, I think I could do this.
- Stud-work, insulate & plasterboard in Utility room as this is currently only a single skin brick wall and will also allow to conceal electrics / plumbing to toilet, washing machine and tumble. I could do this.
- All associated work for skirting, door liners, architraves and supplying and hanging doors which I would have the builder complete.
- Install WC/basin unit which we will supply and associated drainage work. Builder to complete this.
- Drain heating system and move radiator to allow for door opening to be made in kitchen.
- Extend pipework to provide H&C services for toilet, basin and washing machine
- Provide waste pipework/traps for sink and washing machine
- Extend pipework and supply 1 radiator in office area
- Install WC/Basic unit that we are supplying.
- I would have a plumber to all this work as this is not one of my strong points
- Wire and provide power for washing machine, tumble and spare double socket in utility room
- Supply and install LED down-lights for office and utility room
- Supply and install extract fan to utility room
- Supply and install 2x double sockets in office area
- All of this I would have an electrician do for obvious reasons.
Any advice of where to start on this type of project would be most appreciated, I have hundreds of questions in my head but I'll see where the conversation leads initially.
Thanks in advance,
Josh
Thanks in advance,
Josh
