Hi, Just got a question on converting my garage to a spare room and cannot find the answer I'm looking for anywhere on the net.
I have a new build timber frame bungalow which has an integral garage. The garage is the lower than the main house and so I understand the floor will need raised and insulated etc. The garage is completely framed and plasterboarded and is part of the timber frame of the house i.e when the kit was erected the garage was included. I think that there is currently insulation between the warm house walls and the garage walls but I am unsure whether there will be any on the external walls. Would it be a case of ripping all the plasterboarding off the external walls and insulating to the correct spec between studs then re sheeting? My worry about this is that I have a boiler and hot water cylinder in the back corner of the garage and I am unsure what the normal way of addressing insulation behind these are?
The roof is sheeted and insulated above already.
I will be applying for building regs but am just trying to get everything straightened out in my head whilst waiting on this.
Thanks in advance...
