- Joined
- 18 Jan 2011
- Messages
- 1
- Reaction score
- 0
- Country
Need your help!. We are planning on converting our integrated garage into a kitchen. Just for some back ground info, a bathroom sits on top of the garage for its full length and width, the outside wall is double cavity.
Problem i have is the floor of the garage is 8 brick courses below the Damp course. To maintain the level and avoid steps from the existing kitchen (single door to be cut into garage back wall for entrance/exit point to proposed new kitchen) i need to put in a timber floor (width of garage 2.4mtrs) and joists will fall BELOW the current Damp course. Not possible to lower the damp course by chemical means etc as there is a paved walkway that runs down the side of the garage.
Option i'm thinking off is using joist hangers bolted to the wall. Is this permissible or do i need to seal off at the back of the hanger plates where they contacts the wall (below DPC) and also where the bolts enter the wall, and i presume i need to seal off the joist ends.
Any advice would be welcomed as i'm fairly good at DIY but don't particularly want to be caught out with the BCO should they arrive unannounced and i have to rip out the whole lot.
Thanks for taking the time to read and appreciate all feedback.....
I don't want to get into building stub walls to support the joists as i prefer to maximise the area beneath the joists for storage of ladders and timber lengths (5mtrsx2.4mtrs x 6 course high)
cheers
T999
cheers
T999
