Hi All,
We have a sizable double garage and Im thinking of converting one half into an office.
My current plan is to do this with zero structural change to the garage*. Ill basically will be putting in insulation (it's a single brick building), plasterboard, and nothing else, it already has lots of electrics so that's not an issue either
I might change the garage door from a swing to a roller, and I'll more than likely swap out the side door to the garage with a good-quality PVC one.
*the garage has two small side windows, I may opt to have these removed and the gap between them opened up so we can install one large window.
With all that in mind, this will only be an office, no plumbing, no additional electronics, and other than maybe opening a window up no additional building work. Is this something Ill need planning for?
