ok after reading lots and get some advice on here i have come the following plan of action.
Step 1 - Walls
1) Cover walls in DPM sheets temporary fixed with a batten at the top and batten (25x50) running along floor.
3) Place Xtratherm 50mm boards on to the wall wedging between the upper and lower battens and cover all joints with foil tape.
4) Fix vertical 25x50 battens over the insulation board fixing through the board with 100mm frame fixings on 400mm centres.
5) Fix 12.5mm plaster board to the battens therby leaving a 25mm gap betwen the insulation and plasterboard which i can drop wiring through for sockets.
6) Tape all joints, internal corners and external corners.
I have spoke to Xtratherm about this method and they have said placing the battens on top of the board or against the wall makes no difference.
Step 2 - Ceiling
1) Fix plasterboard to ceiling which will be lower than the side walls
2) Fit loft insulation between rafters.
3) Tape all joints
Step 3 - Floor
1) Cover floor with DPM sheets taping any joins and lapping up the walls 300mm (This will partially be done when fitting the walls so the floor DPM goes over the wall DPM)
2) Cover the floor in 75mm polystyrene sheet leaving a small gap around the edges.
3) Lay 18mm WPB plywood over the insulation (should i glue the edges) this again will leave a small gap around the edges.
4) Lay laminate underlay fibre boards and finally the laminate.
Would love anybodys comments on this plan whether good or bad
Dave
Step 1 - Walls
Step 2 - Ceiling
3) Tape all joints
Step 3 - Floor
Dave
