Very quick question on upgrading existing single skin external wall when converting a garage.
I have had several conflicting info. Which is the correct way, working from the outside in..
External Brick
Painted on "Black jack" DPM or equiverlant
3x2 studs with 100mm rockwool insulation packed between
12.5mm platerboard
or..
External Brick
50mm clear cavity
4x2 stud work with 100mm celotex between
12.5mm platerboard
or is there a different way?
Many Thanks
Mike
External Brick
12.5mm platerboard
or..
External Brick
50mm clear cavity
12.5mm platerboard
Many Thanks
Mike
