I am going around the twist with this...
I run a small business from home. I keep some stock in my garage which has a Hormann up&over door with a normal sized wicket door in it. The main garage door is about 4.5m wide and 2.0m high and consists of a very robust aluminium frame with ply facing - it must all weigh the best part of 100kg.
The standard lock (marked 'ZK40') on the wicket door (also in aluminium and integrated into the bigger main door) does not currently comply with BS3261 and is a euro profile mortice lock with latch arrangement similar to that fitted to 99.9% of UPVC front doors the length and breath of the UK (and the EU, too, I would imagine), 60mm backset and 72mm between spindle and euro cylinder centres.
My current insurers say that unless I fit a lock to the wicket door that meets BS3261 they can't insure the garage contents. I can't find a euro profile lock to fit other than those (millions of them) which comply with the EU equivalent of BS3261, EN12209.
Is this normal or are my insurers just being a bit dim/silly? Or is it me?!
Regards, Martin Winlow.
