Chaps
I have two garage doors next to each other in a double garage - one is fine, the other has what looks like wet rot seeping through it, to the extent that it has now created a small hole where it has got through to the other side. Inside, the wood feels 'wet' and there is a damp mark (or what looks like a damp mark) spreading around it, and the wood feels all spongy and soft to the touch in this area.
It also has what looks like mushroom texture (not the shape, but is a white or light brownish growth that covers the hole - this has to be peeled off and within a few weeks it is back. Pictures will be below of the damage (which occurred on the outside and working inwards).
This is the inside of the door, where you can see the area that it has split, and the 'water' mark around it.
This is the external view, with the hole visible although this is mostly covered up by the white fungus that grows over it and along the edge of the line where the woods meet.
This is some of the white/brown stuff that grows over the hole...
Doors are Cardale Timber Heritage Windsor, only built in July 02, and were brand new then (it was a new house), and it seems like I'm screwed on any warranty. Cardale say they do not know and do not care (if you did not ever seal it with the right stuff, then we don't care, they say) and the NHBC say this is not covered in years 3-10, so there is little I can do. So the thing is - what best to fill the hole and more importantly, get rid of the wet rot or even seal it to allow it to dry out, so that I can stop the spread?
The damage is at the bottom so it is not as if you can easily see it, so a simple remedy would probably work - I will then seal both doors properly.
Any help or ideas or anyone been there?
Andy
Andy
