Hello everyone.
Yet more questions from me about my new house!
So I've got a garage en bloc... The bloc has a peaked roof so i wanted to put some beams across the garage at approx 2.80m height to use the remaining space for storage. My question is: where do I stand in terms of being allowed to do this.
The garage is made of what looks like big cinder blocks. The two main beefy rafters are bonded in with cement/mortar (or something like that) into holes in the wall, and I imagine they run through more than one garage.
Can I drill into the cinder block walls and install brackets to support 4"x2" beams using 4 M10 bolt spreading anchors? What is the standard depth of a cinder block.. my conern is that I want to be able to drill into it, but obviously not drill all the way through it into someone else's garage!
Am I allowed to drill and mount brackets into the walls as the garage is a communal bloc (even though the particular unit is part of my own freehold)? This applies not only to the beams but to things like shelves and tool racks?
I'm obviously not structurally changing the wall or making any significant alterations to it but thought I'd double check with you guys as it's my first house in the UK where the laws are somewhat different and interesting!
Thanks everyone
Pavel
Thanks everyone
Pavel
