I have a single skin, brick built garage sharing a common concrete block wall with the next-door neighbour's similar garage. The pair of garages are constructed on a shared concrete raft base and are "stand-alone".
I'm about to extend my garage by 1 metre in width and two metres in length. I intend to build the new walls in block on strip foundations and my question is this:
What's the best way of tying in the old raft base to the new base, which will be concrete infill between the existing raft and the new walls? Should I make it the same thickness as the existing raft edge?
Would I need to reinforce the L shaped new base and, bearing in mind the only load on it will be a workbench or two and maybe half the weight of the car, what sort of mix should it be and whats the chances of cracking appearing between it and the old raft do you think?
