i'm constructing a large garage block (3 Vehicles) which will require usual power points and lighting for typical garage tools. Above this I intend to form a 1 bed flat with usual power & lighting associated with this. However I want to install an electric wet central heating system for rads & hw supply with a power consumption of 9kw. I have an armoured cable laid from my meter cupboard to the fuse board in the garage which is approx 28m long, the cable is 25mm dia overall and has 4 cables within it, each measuring 5mm dia and made up of 7No copper strands approx 1.5mm dia each.
My house has 2 boards, 1 No RCD protected with 9 ways and 1 No with 7 ways, the mains cable into the house is a '35' size as it is 25m from the street.
Basically can I use the armoured cable from the spare ways in my meter cupboard of which there are 2 to feed the supplies to the new development or am I being optimistic? Any help would be greatly appreciated.
