Hello
Doing a self build with a basement garage of 50 sqm on a concrete raft ,the walls are concrete as well joined into the floor and no dpm was installed at time due to concern about slipping
The raft is 350mm thick with reinforcement and has been down for about two years ,it seems ok and is dry
I want to have a good cosmetic finish and boy have i been around the houses ,first i was going to put a screed of sand and cement 70mm bonded to the concrete ,i was advissed against this by the architect who thought it would not take cars and crack ,i then went on the self levelling route ardex k301 which was expensive before actually buying cempolay ultra and sending back as it does not cope with no dpm and if moisture comes up well we know what will happen ,lastly i am looking at laying a dpm on the concrete and then placing 80mm of new concrete and powerfloating it to give a good finish .I will put in some joints engineer is ok with this and had some details from cemex
Any thought and advice welcome ,never again will i be involved in a self build
