Garage floor screed
7 Apr 2005
I am shortly having my garage floor finished with screed.
Questions. First of all this has been build on a 'Raft foundation of concrete'
Was there supposed to be celotex? as i dont see room for it now as 80mm will bring it up level with the driveway.
Second i am not sure which i go for, i see traditional sand/cement screed is cheaper quoted about 900 for my garage area (2.6 m3) Liquid screed about 600 more.
However i want to ensure it is dead smooth as i would like to epoxy or other flat finish. Is this achievable with both?
Thanks.
You wouldn't usually put insulation in a garage slab, no point if it's not a heated space.
Sand / cement is fine, and when done by a pro comes out very very smooth.
A sand cement screed should be at least 50mm thick.
Garage floors are not insulated if it's still a garage.
A screed may well detach if driven on.
An epoxy coating will make a rough finish smooth, but may not smooth out an uneven finish.
Does the raft have a DPM?
