Hi there,
I`ve finally got the go ahead to build a new garage. I`m planning to do most of the plans and excavation myself, get a brickie in to do the walls and possibly floor.
I could do with an opinion on the foundations.
Should I excavate the wall footings, approx 400mm x say 700mm (I know for a fact i`ll struggle to get that deep from previous excavations), and the floor slab. Then cast the slab and footings as one, thus starting my brickwork from the slab level and above.
Or
Dig footings to suitable strata, and start brickwork from there. Then cast the floor slab at a later date once the walls are up, using the brickwork as the majority of the formwork.
Never done anything like this and i'm stumbling on the first hurdle on how best to get the base and walls in place!
i`ll be getting the garage built in single skin brickwork with piers, (I`ll be reading more into insulation and vapur barriers at a later date and its brickwork over block as i can get bricks at good prices) what spacing of piers should i be working to? I have info for freetsnding walls but thats a bit overkill. I had an etsaimate of 2m but i think that might be overkill too. I need this to work out brick quantities, but also i might place a handy member across the garage for lifting out engines etc, and i`d like to plan that location. FYI looking at 20' by 12' ish size.
Roof truss's, I had imagined i`d be able to get some built, or an off the shelf solution, does anyone have any contacts or company names so i could discuss sizes and build a garage that uses a std truss.
trying to plan components now.
Planning side is with council too. Any other info which people might be willing to share is grand.
I have a pot of money to get me started, 2.5k, and then i can afford to throw about £700 per month into labour and materials. I`m in no rush to get it up.
cheers
Alex
Or
cheers
Alex
