I had a new prefab 24ft x 10ft garage errected 3 years ago and the last couple of winters it has been so cold inside the car had condensation and the water based products in a plastic cupboard had frozen
I use a small oil filled radiator but it isn't enough to heat the garage and i just want to stop some of the extreme cold comming through.
A couple of months ago i fitted some plastic floor tiles to help with the ground cold and yesterday i fitted some batons to the walls in prep for some moisture resistant chipboard flooring which i have ordered for next week - this will be fixed to the batons on the walls.
I also fitted some poly insulation in the wall recesses which i'm hoping will help?
I'm also next week fitting Kingspan insulation panels (25mm) to the roof which will be screwed to wooden batons i fitted and i've used expanding foam on the biggest gaps between the roof panels and the wall tops - the eves fillers are fitted all araound.
I've attached some pics of the progress so far and would welcome any further recommendations or comments as to how i can improve things further.
tape holding poly in place until chipboard is in place - should i seal the poly together to cover joins?
roof batons ready for Kingspan - should i seal the roof joins with silicon?
