garage leaking
6 Feb 2011
Cheshire
I have an old concrete panel garage that is leaking in water through the edge at the bottom of a section of panel.
Any ideas to prevent until next year for replacement garage.
thank you
Make the ground outside lower :idea: Otherwise a mortar fillet (outside) or thick bead of mastic may do the trick.
You should give the area a going over with a stiff wire brush first if using mortar, and add some waterproofer to the mix.
I just searched google images for 'mortar fillet' and have made myself rather hungry. :mrgreen:
