I wondered if you could advise on the following scenario?
I have a single detatched garage that i would like to divide and use 2/3 as an office area. This space will be used by myself as and escape from the wife and probably by the wife as an escape from me and the kids!
The property is 4 years old and the garage has a concrete floor and is single skinned with pillars halfway along. I plan on using a liquid damp proof for the walls and floor. I also plan to then build a stud wall all the way around and add insulation. Would i be advised to build a sleeper wall for a suspended timber floor to go on or is this overkill?
Should i instead lay the joists on the floor with nicks cut out for airflow? Will this potencially be a problem trying to get a level floor?
Thank you in advance for any advice,
Regards...
Regards...
