Hello all
I am looking to renew my garages electrics; previous owner was an electrician I am told many years ago.
He was running a 3 core extension cable flex into an old style baker light consumer unit, with a small circuit for a few sockets and an overhead fluorescent light.
I have spent a few pleasant hours running through permutations of garage electrics, outside sockets etc, but not quite found the information I am looking for.
What I would like to do is run a suitable armoured cable from the main consumer, into a sub box in the garage, and to the use that to run a ring main round the outside of the garage walls, with 7 twin sockets spread about I am thinking 6mm twin and earth for this?, and a light supply and the kicker question a single feed to run a 25A, 4.2Kw pottery Kiln for the wife to play at pots.
The run from the main consumer unit to the garage unit would be 36ft or 10.97 meters, The garage is 38ft long by 9ft wide.
The information I have winkled out so far is I need the internal cables in conduit, with sealing glands ideally going into metal back boxes.
I am hoping to run a compressor and welder of the ring circuit as well.
I have attached a diagram outlining what I would like to do, I am aware that I need the cable to be correctly rated, I am also aware that building control need to inspect this before commencing.
I have a spare on the main consumer unit, it’s a new unit only 4 years old it’s fitted with its own RCD unit, the main house was rewired at the same time, me being a donkey did not think to get the garage done at the same time.
For my own piece of mind I was hoping to get a pointer into if the above is doable, what sort of armoured cable I would be looking for size wise?
I don’t want to scrimp on this as the idea of melting cables when the wife turns the kiln on does not fill me with happy thoughts.
My plan is to get a sparky in to advise and connect, with me doing the donkey work for him, if that makes sense, but would like to have some idea of what’s involved so I can detect any cow smells that may emanate my way.
Thanks for looking.
Thanks for looking.
