I'm looking to replace the corrugated sheeting on my sectional concrete garage. The garage was originally from Compton Garages in 1997. A couple of the sheets have cracked along their entire length, and a couple more are showing signs of doing the same.
As the garage dates from the late 90's I'm reasonably sure that they are Fibre cement, but as the rules regarding the use of asbestos sheets didn't come into force until 1999. So there is a chance the may be asbestos.
Having read up a little on the risks involved should it be asbestos, it appears to be fairly low risk, that it does not require a licence to remove it and is not notifiable.
So a couple of questions.
1. Is there anyway to determine which it is for sure Fibre or asbestos?
2. Who and where will dispose of it? (I'm quite prepared to disassemble the roof and double bag it as per the HSE guidelines. But who will take it and how much are they likely to charge?
Not decided whether to replace it with Fibre cement of more modern metal cladding type roof. So any advice on that welcome.
Cheers
Cheers
