Hello chaps,
I've decided I'm going to replace the garage roof; it's asbestos cement, and its leaking pretty badly. I know about the disposal procedures for the panels, so that's not a problem.
I'm going to replace the sheets with that Coroline corrugated stuff. The first thing I notice about the stuff is that it looks really flimsy but I guess it should work.
I've been going through the procedures, and trying to adapt what I've got at the moment. The purlins are metal and the current sheets are attached to these using skyhooks, those 'J' shaped hooks. I believe it's best to use those special nails for fixing the Coroline onto the roof, so I'm going to bolt wooden joists onto the metal frame, and nail into that.
First question is whether that's a good idea.
Next bit is that the purlins are about 120cm apart, or 4 feet. This suggests that I need extra purlins in place, as the Wickes "how-to" leaflets suggest 450mm ~ 600mm spacings. I don't particularly want to do this, as I'm sure it'll add to the cost (there is a tight budget on this!). Indeed, I can see this being a lot of hard work as I'll have to somehow attach these extra purlins to the exterior walls, and I'm not sure how this can be done - is this an easy job? Do I have to remove some of the exterior walls so the joists can get slotted in?
Third bit concerns the slope of the roof. It's one of these pre-fabricated garages, (a double one, approx 5m wide), and the slope is very gentle, probably around 5-10 degrees. The leaflets say I should have boarding to go across the whole lot and then put the coroline sheets on top of that. I think this is the way I should go, but I'm not sure if the thing with the purlins still applies. What boarding do I use? Can 6mm exterior plywood do, or do I have to go the whole hog and use that OSD roofing boards at 20 a shot? The prices are roughly the same, but I'm worried whether the weight would cause a problem.
As I say, my budget is tight. My current estimate is for around 300, but that doesn't include any joists or boarding.
Any advice would be greatfully received. I'll be starting this when the weather improves, probably Easter weekend.
Cheers,
MrP.
Cheers,
MrP.
