Corrugated metal garage & roof, trusses are triangular and about 6ft from concrete floor. I’m 6ft6 and have a sore head. Can I brace the joists with metal or wood and cut out the bottoms of them? If so how do I do it and what materials should I use? Thanks
Yeah that could be a solution.
Cut the wall plate straps and jack one side up then lay a course of brick. Leave it a few days repeat for the other side.
