Garage to house 100mm step
24 Jul 2005
The 100mm step between the house and garage can it be made up of ie:brick course 75mm + 25mm wood threshold or does the whole 100mm have to be solid brick/concrete then threshold on top of that
nyck
my 20's house has brick thresholds.
the bricks are layed with their stretcher faces perpendicular to the threshold and rest on the stretching face so the arrangement looks like bricks forming a lintel above a window etc.
the bricks used are different to those of the adjacent wall, they are of a very dense type. The mortar between these bricks is also perculiar, it is a portland cement mortar and a very ritch mix.
The building regs just says 100mm step, it doesn't specify material. As mine is a timber stud partition in that position, it will be totally wood.
