I'm building a new 20sqm garage to replace an existing prefab garage that leaks from bellow and above. I'd like to insulate it to a reasonable degree so I can heat it if I'm working on a project in the winter.
I'm thinking that I will use 25mm celotex insulation to keep the overall thickness down, but can't fathom if I need to use any ventilation or membrane layers?
(edited to clarify I will be building using block for both skins - had thought about wood for the inner skin but pillars become an issue.)
