- Joined
- 17 Apr 2004
- Messages
- 39
- Reaction score
- 1
- Country
Hi, looking for some advice.
I have a garage with existing wiring from my consumer unit to the garage. A single 2.5mm T&E to a fused light switch and a single socket. Last year I built a summer house and installed the cabling for 2 double sockets and a pendant light switch. I ran 4mm armoured cable underground (20m long) and into my garage where it stops. I now need to get everything connected. I intend to replace the cable from the house to the garage. I intend to add 1 double socket in the garage at the same time, one of which will run a tumble dryer and the other a freezer. Id like to know...
1. What size of cable should I use going into the garage? (its about 4 m from the consumer unit). The summerhouse will not be supplying anything that will need a lot of power.
2. Will I need an RCD protected new consumer unit in the garage for my summerhouse supply and garage supply?
3. Anything else you might advise.
Much appreciated.
Much appreciated.
