Right, I've planned a project through, and I thought it would be wise to verify it with people more in the know than I believe I am.
The project is to install a bunch of new wiring and fittings in the garage. The proposed curcuit will contain the following:
A) The output of current consumer unit will be routed through 10mm (rated 53A) T+E from a 40A MCB.
B) An IP55 rated garage consumer unit, containing a 63A, 30mA RCD to disable the whole CU. and a 6A and 20A MCB.
C) 3x two way metal clad, 13A sockets
D) 3x fused, metal clad 13A spur boxes (for perminently wiring machinery into)
E) 4 way metal clad light switch
F) 4x 58W floresent lights
My questions are as follows:
Note 1) Is the specs for the consumer unit acceptable along with the T&E to main consumer unit?
Note 2) All the sockets and spur boxes for this run will be wired in parallel internally,is this sort of center tapped spur acceptable? Enclose in metal clad box?
Note 3) 4mm T+E, Rated 32A, fitted to 20A MCB sufficient for application?
Note 4) 1mm T+E, Rated 14A, fitted to 06A MCB sufficient for application?
Note 5) Neutral and earth lines all internally connected, Live switched, acceptable?
All wiring will be housed in 20mm plastic conduit with grommits fitted where necercery to keep wires away from bare metal.
All metal clad enclosures earthed.
If anyone has any other comments on this, I would welcome them.
I'm aware I have drawn this in the old wiring colours, I am doing so as I hope to aquire some old cable... I assume anyone who can comment on this post will know why. But dont make a big deal about it
Cheers,
Sam.
Cheers,
Sam.
