hi there, i just completed an install in my garage and although not a fully qualled elec to uk regs i am a military electrician currently doing the conversion courses ! 2391 , 2382 etc..
just need to know if i have done the work correctly for my benifit and also for when i come round to getting it tested by a local electrician who is also signing some of my work of for my nvq3.. dont want to look stupid.!!!
SUPPLY FROM CU located in house RCD 32Amcb 4mm T&E (6metres)(this was already left from the house builder connected to a single socket. so i utilsed it and fitted the CU as described below)
to
63a CU located in garage with RCD protection, 32A and 6A mcb.
6A = 1 way lighting circuit (strip light on ceiling of garage.)(built with 1.5m single's enclosed in 20mm pvc conduit.)
32A= radial circuit with 3x 13a double sockets and 1x 13a fuse way for connection of a freezer with out sockets. (built with 2.5mm singles enclosed inside 20mm pvc conduit)
can any body think of any thing i may of done wrong or any alterations .
a ring circuit would not be benificial as it would be a waste of cable and un economical
to
