I remember seeing something on T.V about some famous celebrity who had a minature "dome" (remember that) put up in his garden his neighbours complained and objected because he didn't have planning permission. The tv programme mentioned he didn't need planning permission as it was only a temporay structure. so i Guess it depneds on your view of temporary.
Depends on where you are putting it, how big it is, and if the property has been extended before. You could ask your local planning office - they can be quite helpful. Ours (Charnwood) send out an idiots guide which I found very useful.
If you don't want to talk to them Mr Prescott has put all of the relevant stuff on line at http://www.planning.odpm.gov.uk/guide/. It's very windy, but the info is in there somewhere.
General rule of thumb is you need permission to build between your house and the highway, if the new whatever is to be over 3m high at your boundry, if you have used up your permissable building rights, if you are in a conservation area.
You may not need permission for a building no more than 3m high (4m with pitched roof) more than 5m from the house - so a garage at the bottom of your garden would be easier than one next to the house - provided the house and out buildings do not cover more than 50% of the plot.
I enquired about this to build my garage/shed extension and I don't have to have permission. In my area, anything under 70 cubic metres doesn't need permission. (be it brick, wood, tiles, felt..anything!) (I'm in North Hampshire)
If you are building within 5 meters of your house, you are (usually - special circumstances may apply so it is prudent to ask of your local authority) allowed a certain percentage of the volume of your property or a fixed amount - 50 cubic meters for a terraced house, 70 for semi or detatched - which ever is the greater.
