hi, 2 years ago i laid a path around my garden shed and veg patch using some sort of "golden" gravel (all sorts of golds yellows browns and whites) i bought the weed membrane from wicks as it was on offer and laid as the packet said so which was to- lay a layer of sand then put down the membrane then put down more sand then put the chippings on top. i did this but have always had the problem of quite a few weeds coming up through the path and a lot of sycamore trees as a tree nearly overhangs the area, would i have been better off not putting the sand on top as i think this is what is giving the weeds something to grow in? the reason i ask is because im about to lay borders around the garden with probably purple slate chippings and don't want the hassle of weeding it! If the sand is the problem am i better off trying to get the sand up which wont be an easy task as im sure i put about 5 ton of gravel on it altogether but if it helps im sure i could eventually get round to it
Also was wondering about the original path, since laying it it has turned a bit green and dirty, i obviously cant pressure wash it so was thinking of either using some diluted hypochlorite and keeping the kids and dog away for a while or maybe a patio cleaner either way leave it on for a few hours then rinse off, any ideas?
any thoughts/plans greatly appreciated
